41 - 52 of 52 Posts
2017 Sportsman 850SP
Nah, I think it’s the exhaust that is giving that illusion 🤣
I use channellock oil filter pliers to adjust my springs.
If the tops of your tires are learning towards each other, cranking up the pre-load can help.
I ended up going with HD springs on the 570 and it fixed the problem. I put them on the 850 too before it became a problem.
Details please on that LED light!???
CMOS
Sure, that’s the OEM rear work light. You can remove the blank and install either the white work light, or a third brake light. The wiring is already there. If you do the white work light, you add a switch and use the yellow wire that is in Pod.
(XP chassis only)
Reactions: Gmartino100
Part number? This is a Polaris part?
CMOS
FYI, If your signature line is correct and you indeed own a 450 this light is not designed for your ATV, it is only designed for an 850 or 1,000 Sportsman.
41 - 52 of 52 Posts
