Hey guys, I want to order some hd springs for my 2013 sportsman 500 . As far as I can tell, polaris only makes springs for the front, and I can't find a listing for the rears with Epi or highlifter...the listings only go up to 2012...has anyone put these on a 2013?
Check out any website that sells OEM parts like polarispartshouse.com. See if they list the same part number for the springs of a 2012 and a 2013. If its the same part number for both model years then you'll be fine putting the 2012 springs on.
Im sure 2012 springs will fit. But shoot an email to highlifter to double check.
That's a great idea. CHK part numbers between the years. SHOULD jive. If not do t freak because still likely same.
A knowledgable parts guy at the dealership should know and simply looking for yourself at a shop that has both to compair would also tell you.
Maybe someone here with a 12 could snap some good pics for you?
I got mine from atv superstore for front and rear. They arrived super fast too.
Sent from my MB886 using Tapatalk 2
