Have a 97 Sportsman 500 that just developed a squeak in the left front end while driving in 4wd. The faster i go, the more noticeable it is. Doesn't seem to be present in 2wd. Any ideas on what this might be?
when is the last time you did your hub oil...and greased bearings.....I would start to look there first..and grease your A arm bushings while in there....like Polman said...you may have a dry hub and see when you drain hub
You cant grease those bearings, they are tapered roller bearings that get lubed with ATF or whatever Polaris fleeces your for. Change the fluid in the hubs with synthetic ATF.
your right...i was thinking back since i just did mine...
