has anyone else ever done anything to the steering post bushing to stop it from squeeking i sprayed it with wd40 and it stopped but am thinking of drilling it and tapping it so i can put a couple grease nipples in it. any thoughts
Mine had a grease fitting from the factory - a little waterproof high temp grease and it's good from service to service.
WD40 evaporates and dries after a short while and will make it squeak worse. If you're gonna use a spray on it get a penetrating oil with silicone.
just wondering where is your grease fitting i see a new bushing has a hole in it towards the front of the bike under the headlight is this where your fitting is?
The older Sportsman like the 96 pictured here had grease zerks on both the top steering bushing #7 and the bottom bushing # 9 But they also had about 20 other grease fittings all over the machine too! Polaris determined years ago that we didn't need all those pesky grease fittings and that the bushings, u-joints and other moving parts should henceforth be "greaseless" "lifetime" parts lol. Trouble with that is a machine running in the dirt, mud and water a lot the "lifetime" is shortened significantly when you don't have lubrication on the moving parts.
136694
update was out in shop this morning hole is there but wasn't threaded so i tapped it and installed grease nipple and greased it thanks for all the help
I did the same works great!!
