2019 sportsman 570 2020 sportsman 850
My sportsman 570 will stop on a dime but the 850 requires quite a bit more pressure to stop. I wanted to see if any of yall’s are the same way before I go get some dot4 and add/bleed the system.
Try adjusting them with the screw on the caliper before you bleed them. Oh and chk them before you adjust them. As they may need new pads. One thing I've noticed is the pads fade more when they are low.
I bought it new in March and it’s always been that way. I will check out the screw
ok yup chk the screw and hopefully that's it.
