I don't like the Start switch on my 99 Scrambler. where you have to slide to start position then push up on the slide part to start.
Is there a swap out there where you can go to a push start button?
More like a normal streetbike.
I have seen a few on ebay like this, just not sure if they have the Reverse override also.
thanks
Welcome to the board!:med:
You'll need to check the wiring diagrams for both bikes. You can probably mate the earlier switch with some work.
Not sure why they went away from the push button style, it just seems so much easier. OR maybe my switch is just harder to push up on..
I'm pretty sure it will work with the other style switch.
without looking at the schematics, Im pretty sure both switches are wired the same, they just moved the push button to a push/up style.
I'll post updates, if I make the swap. might be a while.. got home projects to do right now.
thanks
