Hello could use some help I have a 98 magnum 500 where the starter bolts to the motor housing was stripped out at one point and someone drilled it out and ran a bolt threw it to hold the starter in well it gave out and broke the mounting point for the starter just try in to figure out a way to fix with out having to tear it all apart any ideas would be greatley appreciated
You'll need someone that can weld aluminum, and have weld a gob on the bad spot, shave that down and retap.
You'll have to take the motor out for this.
