I have a Sportsman 500 and the starter doesn't engage when it is below zero outside. Sometimes the pull start doesn't engage also. When I bring it inside and warm, it will engage and start. What could be the problem?
Not sure what you mean about the starter doesn't engage,my starter would not turn over at all unless I put my heater on it, changed the starter relay and now it works.
The recoil is your pull start, and at the bottom of that case is a drain bolt. Remember, if there is water in there you have to get the atv somewhere heated so it's a liquid and not still frozen inside
