1 - 10 of 10 Posts
hay friends I have a 1999 trailblazer that I have bought 3 starters and none will fit.watched youtube vid.and feller took one out,his had a big hole where bendex goes and mine has a small rectangular hole in bottem of dendex well.what do I have ?im lost and don't know what I need,any help thanks
You need a Bendix - the rectangular hole is where the reduction gear engages the starter motor armature - it looks like the starter motor is missing the armature
Do you have a pic of the new starter you got?
You need starter motor # 3087043 and Bendix # 3080034
The parts pictured should be the parts needed to replace your starter.
The original part # for the 97 Trailblazer was 3085392 - it superseded to 3085393
Today, part numbers 3084402, 3085282, 3085392 and 3085393 all supersede to 3087043 - these starters were used on the 1996 to 2006 Trailblazer 250 and the following models:
1991 TRAIL BOSS 350L 2X4 (W917539) - Starting Motor Assembly 350 2X4 Update
1991 TRAIL BOSS 350L 4X4 (W918139) - Starting Motor Assembly 350 4X4 Update
1992 BIG BOSS 4X6 (W928627) - Starting Motor Assembly 250 4X6
1992 BIG BOSS 6X6 (W928727) - Starting Motor Assembly 250 6X6
1992 EURO BIG BOSS 6X6 (S928727) - Starting Motor Assembly 250 6X6 / W928727
1992 EURO TRAIL BOSS 4X4 (S928139) - Starting Motor Assembly 350 4X4 / W928139
1992 TRAIL BOSS 250 (W928527) - Starting Motor Assembly Trail Boss
1992 TRAIL BOSS 2X4 (W927527) - Starting Motor Assembly 250 2X4
1992 TRAIL BOSS 350L 2X4 (W927539) - Starting Motor Assembly 350 2X4
1992 TRAIL BOSS 350L 4X4 (W928139) - Starting Motor Assembly 350 4X4
1992 TRAIL BOSS 4X4 (W928127) - Starting Motor Assembly 250 4X4
1994 300 4X4 (W948130) - Starting Motor 4X4 300
1995 300 2X4 (W957530) - Starting Motor 2X4 300
1995 300 4X4 (W958130) - Starting Motor 4X4 300
1995 TRAIL BOSS 250 (W958527) - Starting Motor Trail Boss
1996 400L 6X6 (W968740) - Starting Motor 6X6 400L & 6X6 400L Norwegian N968740
1996 NORWEGIAN 400L 6X6 (N968740) - Starting Motor 6X6 400L W968740 & 6X6 400L Norwegian
1996 SCRAMBLER (W967840) - Starting Motor Scrambler
1996 SPORT 400L (W968540) - Starting Motor (4935863586D009)
1996 SPORTSMAN 4X4 (W968040) - Starting Motor Sportsman 4X4
1996 TRAIL BLAZER ES (W967827) - Starting Motor W968540 (4935863586D009)
1996 XPLORER 400L (W969140) - Starting Motor Xplorer 400L
1996 XPRESS 300 (W969530) - Starting Motor Xpress W969540 (4935923592E004)
1996 XPRESS 400 (W969540) - Starting Motor Xpress (4935923592E004)
2001 TRAIL BLAZER (A01BA25CA) - Starting Motor
2001 TRAIL BLAZER (A01BA25CB) - Starting Motor A01ba25ca
2001 XPLORER (A01AG25CA) - Starting Motor
2001 XPLORER 400 (A01CG38CA) - Starting Motor
2002 SCRAMBLER 400 2X4 (A02BA38CA) - Starting Motor
2002 SCRAMBLER 400 4X4 (A02BG38CA) - Starting Motor
2002 TRAIL BLAZER (A02BA25CA/CD) - Starting Motor A02ba25ca/Cb/Cd
2002 TRAIL BLAZER FREEDOM (A02BA25CB) - Starting Motor A02ba25ca/Cb/Cd
2002 XPLORER 400 (A02CG38CA) - Starting Motor
2002 XPLORER 4X4 (A02CG25CA) - Starting Motor
2003 TRAIL BLAZER 250 (A03BA25CA/CB) - Starting Motor
2003 TRAIL BLAZER 400 (A03BA38CA) - Starting Motor
2004 A04BA25CA TRAIL BLAZER (A04BA25CA/CB) - Starting Motor
2005 TRAIL BLAZER (A05BA25CA) - Starting Motor /Cb
2006 TRAIL BLAZER (A06BA25CA) - Starting Motor
The pictures confuse me - it looks like the old starter broke away from the mounting flange - I could tell better if I had it in hand
Hello new guy on this link got your name while serching for info on changing cam on 2004 400 4x4 sportsman . Not ho but is the late 2004 model (Found this out when changing the computer mod ) have full post under newbie page under bob6x on polaris page . Have change carb ides great cuts out at have throttel but runs fine to that point , is it a hard job changing cam . Is there a good manaul out there . Have read basics Strip plastic and tank get motor TDC pull gear keep tension on timming change set valves at .006. Any info helpful thanks
1 - 10 of 10 Posts
