anyone know how to take off starter on a 1993 350 trailboss i tried but no go!!! any if anyone knows where i could find a manual thanks
I hope someone can help you here!
Some had a bolt from the inside behind the bendix if I remember correctly if not you need to bump it out. There is a o-ring that seals it into the engine case. Take a big flat blade screwdriver and a hammer and jentky tap it out:eek:
A 2# sledge should do it!:p
If it don't a 20# should for sure:D
