1 - 18 of 18 Posts
Guys,
I have a 2007 (I think) 500 EFI Sportman. Is outside much of the time. Has less than 50 hours on it.
Started having starting problems with it after a cold soak when the temps got down to near zero. Switch on and you can hear the fuel pump tick and stop. Cranks fine ... no fire. Crank a lot and it eventually fires. Sometimes seems to help to flip the run switch back and forth.
Is like there is a leak in the fuel system so that it takes a while to fill fuel line ... but can find no leak.
Have added fuel line antifreeze to the gasoline (which is unleaded EXXON high test).
Is a PITA to have problems with the ATV when you really do need it.
Thoughts?
Mike
the reason i suggested the spark plug is that when an EFI first starts up it is running on its rich map. when you start them up and run them a short time, say, to move them into our out of a garage or trailer, ect. and turn them back off, you get excessive amounts of carbon build up on the plug. if you let the machine warm up and get out of its rich cycle it burns the carbon off. and EFI should be pretty gentle on plugs, but there is always this possiblity. for instance, at the shop, we move some machines from our back lot to the sidewalk for display and back at night. we are happy if our EFI machines dont foul plugs in only 5 hours run time. usually have to change out plugs every 10hrs or so of run time
almost sounds like your EFI is not trying to start in its rich mode. this would also explain why after its running and you shut it off it will fire quickly, but is harder the longer it waits
you will have to remove on of the side panels. although i cant remember of the top of my head which side has better access. anyway, pull the side panels off, and then if you have the OEM spark plug wrench that came with your machine, use that, it works pretty well. pull the spark plug wire off of the spark plug. WORD OF CAUTION!!!!!!!!!!! i would absolutly take a fine tipped air compressor nozzle and blast a buch of air in the hole the spark plug is in after you have removed the plug wire. you want to blow any and all dirt that is in that hole out of there. you do not want that to fall in after the plug is removed and have it take out your piston rings.
put the plug wrench on the plug, and untread it just like a bolt. put the new plug in, screw it into the motor, (start it by hand first and get a couple threads going before using the wrech so you dont mess up the threads) push the spark plug wire back over the top of the plug, should feel a little "pop" once it is seated right over the plug, and see if it fires up better.....
if not, its only a $2 plug and 15-30mins of your time. start with the simple easy cheap possibilities first and ill help you work up from there. let me know if a new plug helps at all
Discussion Starter · #9 ·
OK Will try it. Is the plug standard or do I need to go to the dealer to get one?
How do the side panels come off?
Do have a source of compressed air ... good idea to clear the plug well first!
Thanks,
Mike
the spark plug is pretty basic. they are $3.19 from the dealer but all you really need as something like an NGK BKR6E, should be like $2.99 a plug or so. autopart store, lawn and tractor store should have them, should be pretty easy to find.
pull your seat off. (small tab at rear of seat, pull up on the metal bar tap and lift seat away) side panels basically flex off. they have a small channel that the body plastic rests in. just grab and twist them and they pop off pretty easily. put them back on the opposite way. you will see what i mean when you get there. there are no fasteners or anything to worry about.
i do agree that hour wise you shouldnt need a new plug but, what you have is a symptom of a bad plug. start with the easy things first. let me know if this gets you anywhere and if not we will go from here
Discussion Starter · #14 ·
Could not bet NGKs locally. ATV shop is 30 miles away, so I settled with AutoLites. Got the side panels off ... was easier than I thought.
Found the plug and the plug wrench.
JCH!!!! That is a pitiful place to work in ... the designers must have TRIED to make it difficult. I can get the wrench on, but there is no room to turn it. Going to have to try using a socket with a wobble joint when I can get to my shop. Would love to give the SOB that designed this thing a piece of my mind.
Mike
yeah, its a tight fit. i have skinned my knuckles countless times doing that.
i belive it the older 700s or something, but i remember it was a polaris twin atv and the rear cylinder is almost physically impossible to get to. it could be worse
Discussion Starter · #17 ·
ATV now has a new symptom ... is taking a very long time for the fuel pump to get enough pressure up for the computer to think it's ready to try to start. Once started it wil restart fine if done in a minute or so after shutoff. If more than that, the fuel pump will click quite a while and it's hard to start again.
It seems to be losing fuel pressure in the lines somewhere or the pump is kaput. What should I look for???
Thanks,
Mike
1 - 18 of 18 Posts
