I have a 2013 Polaris scrambler do ho. I replaced the starter, starter relay, and battery and when I turn the key all the lights and turn on like normal, then I turn the key to start the four wheeler and all I get is one click and the lights turn off for a second and come back on. Any ideas?
Bad connection somewhere in the line.
Ditto ^^^^ - bad connection or not properly activated battery.
Since the battery is NEW - was it activated (charged) to a full 13.2 volts before use? Are the battery terminals adequately tight? Is the frame ground clean and the battery negative cable adequately tight where it is attached to the frame?
