1999 polaris magnum 500. Will not try to start (will not crank). Battery is charged. little red lights (led) in run switch and light switch come on. Nothing else. will start by pull cord. Can anybody help?
Welcome to the board!:med:
Try jumping across terminals on selenoid, if it starts , probably selenoid or bad connections, check all connections at battery and selenoid first, if it doesnt start maybe bad starter, try hitting starter with a hammer while you try to start it, sometimes brushes get stuck
