ne day my daughter was riding my 500 and it just died i have put a new plug in it ,drained the carburator, drained the fuel tank and put new fuel in the fuel tank. It cranks good but will not start i checked and fuel was going through the lines i could use some ideas and help thanks.
Welcome to the board!
Is it getting spark? Did you pull the plug and verify a good blue hot arc? Sounds like a spark issue to me, could be the cdi box, plug wire, who knows...
Also, check the intake hose - the one that goes from the front of the carb to the jug. On my '96, I had an issue similar to yours caused by that hose being loose, allowing the engine to suck WAY too much air. New clamp solved all my problems.
HTH!!
-J
