92 TB 250. If I can't it with starting fluid does that eliminate a fuel problem. Rebuilt carb. Tried fluid into piston nothing. Good spark. I'm thinking piston. Will check compression tomorrow. Any other ideas.
How's it going Bruce?
If it won't start with starting fluid, with good spark.... I'd say you either have a compression issue or exhaust blockage. Hope this helps
