My Polaris magnum 425 97 doesn’t want to shift into high or reverse. I don’t understand what is happening it’s starts up and goes into low but not high or reverse. Any suggestions?
Idle is set normally at around 600 to 900 rpm. It got fixed recently to be running but they left a ton of Things because it was really overpriced. For about three things it was around 2k (carb replacement) (starter rebuild) (and other thing that it needed.
If the shifter rod is moving and the bellcrank (#13) is turning the shift shaft (#16) - either there is a problem with the shift shaft, shift fork (#8) or the shift dog (#48). So either the problem is internal or external. Let us know what you determine.
Thank you for this info I will check again on it when possible.
Related Threads
posts
922K
members
127K
Since
2008
