Just now rolling over 100k miles. Been feeling some steering weirdness so I get one front wheel up in the air and push at 3 and 9 and sure enough there's some wobble. Pushing at 12 and 6 gives no play at all.
Although I'll probably be replacing the worn part myself I need some help diagnosing what all might need to be replaced. And since I need an alignment anyway I've made a deal w/ my local Goodyear tire shop to do a pre alignment inspection and identify my bad part(s) so I can replace them before they do the job.
When I drop the car off what specific parts should I ask them to look at? I'm sure tie rod ends but what other kind of worn parts could be causing movement on the 3-9 push test?
Anytime I've had movement like you describe it's been the front unit bearing / wheel bearing.
Sent from my SM-N950W using Tapatalk
what are you working on??
