Are the stock paper air filters reusable? How do you clean them? If reusable How many washes before it should be replaced? Thanks
That's not a good idea. Inevitably there will be fine dust that enters the inside of the filter, which in turn will find it's way inside the motor. Blowing it out with a compressor is even a worse idea. Whether you see it not you are damaging the filter.tap out the outside layer of dust. I do this periodically until the unit looks pretty dirty and/or lots of sun is blocked when holding it up to light. The blowing/tapping just knocks the loose stuff out and gives it a little longer life...
I hear ya, i should have said at low pressure, i often am too lazy to fire up the compressor so i just tap em. I've seen plenty of mechanics do the same with a quick psst of air from the forward direction of the air travel backwards. If you bend em well better have a replacement ready! I usually only do this once and then within a month replace it anyway. :cowboy:That's not a good idea. Inevitably there will be fine dust that enters the inside of the filter, which in turn will find it's way inside the motor. Blowing it out with a compressor is even a worse idea. Whether you see it not you are damaging the filter.tap out the outside layer of dust. I do this periodically until the unit looks pretty dirty and/or lots of sun is blocked when holding it up to light. The blowing/tapping just knocks the loose stuff out and gives it a little longer life...
Not saying your wrong but how do you know that?That's not a good idea. Inevitably there will be fine dust that enters the inside of the filter, which in turn will find it's way inside the motor. Blowing it out with a compressor is even a worse idea. Whether you see it not you are damaging the filter.tap out the outside layer of dust. I do this periodically until the unit looks pretty dirty and/or lots of sun is blocked when holding it up to light. The blowing/tapping just knocks the loose stuff out and gives it a little longer life...
