The newer stock tires really suck, but they will work fine, you will just slide around a little more. Add weight like someone else said, or you can put screws in the tires, but be careful as the stock tire lugs are not as deep as most aftermarket rubber...
Sent from my DROID BIONIC using Tapatalk
