1 - 8 of 8 Posts
Hi everybody!
I'm new in this forum and i want to ask if someone have similar noise on his ATV and how to fix it!
I have a Sportsman 550 XP Forest 500km, 10 months.
Here a video where you can see the noise:
Can someone help me?
WD is a big dirt attractant and will make things worse over time by causing premature wear. Try a wax based lube such as Fluid Film, or White Lightning etc.
Discussion Starter · #7 ·
I tried to lubricate the joints and the noise is decreased a lot! I will provide to take a specific lubrificant. Any suggestions?
Thanks all
Check the bushings on the sway bar. Mine made that same noise for a while. Cleaned them good with some car wash soap and the squeeeek is gone. Never use an oil based lubricant on rubber bushings.
1 - 8 of 8 Posts
