My mother in law has a 2003 Polaris 4x4 atv, automatic (unsure of make and model right now). It is stuck in reverse. Took it to dealer and spent 800 bucks and first time we used it, it got stuck in reverse again. Any thoughts on if this is something that should/can be fixed and what if might be?
I've never heard that one before but I am new around these parts! And welcome aboard!
check linkage
you may want to check the linkage to the gear box. will the shifter move? or is it stuck too. if so you may have a prob inside the gear box.
Cluthhman is right. Disconnect the shift link and move the lever on the trans with your hand. It won't be to easy but it should go. If you can get it to move you should be able to get it out of rev. You might have to rock the machine to take the gear pressure off.
