1 - 20 of 21 Posts
Hello boys I've got one for u I have an 06 sportsman 500 HO that acts like it running out of gas at WOT I hav rebuilt carb changed air filter rebuilt fuel pump checked all lines hav not changed fuel filter but it seems fine tank vent is clear also mixture screw is set at 2 1/2 turns out I hav also checked clearance in thumb throttle box it's fine also plz help don't know what else to do. O it idles perfect and runs perfect until I stretch it out to WOT
What exactly does it do at wot?
Have you checked the cams? This may be the first sign that the exhaust lobe is on the way out.
Discussion Starter · #6 ·
At about 5000 rpm it just loses power like its running out of gas come to a stop and it fires right back up. Have not checked cams becuase it runs to damn good other wise. Jetts are fine already checked that twice. When rebiult carb I didnt change float level. Where should it b set
Discussion Starter · #8 ·
How would I now if its set n correct position just asking cuz I know I didnt move or dont think I did anyway. I just got new fuel filter on today but havnt gotten to try yet. Gotta 2 year old and a 4 year old ar home today lol.
I'm thinking fuel filter , couldn't hurt to change it anyway , it's cheap and easy too
Discussion Starter · #15 ·
It operates very well in low gear. No symptoms of any kind. Put it in high gear an stretch it out in WOT AND I MEAN THROTTLE ALL THE WAY TO THE STOP for about a quarter of a mile n it just acts like it runs out of fuel. Stop hit the key and it fires right back up like nothing wrong until I hit WOT again. But put it in low and its all good
Does it stall too since you have to "hit the key" and "fire back up" after this happens?
Discussion Starter · #18 ·
Alright boys here an update. I got float set correctly. New plug old one had crack I found with magnifying glass. New airfilter and fuel filter. All squeeze clamps replaced with real hose clamps to stop any leaks of any kind . Took it for a ride as hard as I could around short trails at house it did awesome hasnt been this strong since I bought it in 06. I do believe it was the plug and float set at wrong level causing the problems. Thaks for all yalls help. NOW MAYBE I CAN MAKE THE NEW YEARS RIDE AT WOOLYS OFF ROAD OR WHEELIN IN THE COUNTRY. THANKS AGAIN FROM SANTA FE TENNESSEE BOYS.
Glad it's back to normal for you :fing02:
1 - 20 of 21 Posts
