I rolled my bike over in a water whole pulled it out drained the oil and everything but it still won’t start I know it’s for sure getting gas air and spark so it makes no sense
can you rotate the engine??
your going to need to go through the electrical connectors; blow them out, clean them with electrical connector cleaner, and die-electric grease them. that's the first step.
What would the main ones be because most of them are greased
Spray some Start ya Bastard or what you call it there areo start what ever in the air intake if it don't fire or run than you have no spark or no compression or no piston connected to the conrod if it gulped water in the cylinder while running.
well if you greased them then you should be good and they didn't take on water. whats the fuel pressure?
