I received my Superwinch Terra 35 today. I am using the Superwinch mount as well. This is going on my 2013 850 Touring by the way.
1st problem is reinstalling plastic covers. What I will call the fangs part strikes the bottom of the roller fairlead when trying to reinstall. The BLUE circles will highlight where it needs to align. Picture below will show the area that appears to need removed in RED. Does that part of the plastic have to be cut out?
If I remove that area in RED above then I can no longer install what I will call the grill. You will see in the below picture that the area which would be removed is where the grill rests against the fangs when installed. I used RED X's to show contact points.
I have seen topics on here before where people were able to still use the grill if they just cut away the center area for the fairlead to come through. How are they achieving this?
