I bougth my new polaris sportsman 2018 570 sp efi and sometimes when i am passing a bump or a small pit there is a noise from the front under like two metals hitting each other like a “tak” noise does anyone have any idea what it can be? Thank you for your help! 🙂
Something hitting something - maybe a loose shock, bad a-arm bushing, ball joint or cracked frame? Might just be a loose steering shaft bushing.
give the prop shaft a wiggle. may have a bit of play in it which may cause it to hit the frame.
Check your motor mounts. Also is the battery strap installed? One of mine makes all kinds of noises since new (at 300 miles). The other at 2000 is quiet. Both are 19's.
