Would it be worth it to go from 26" swamplites to either 27" or 28" zillas? some ppl say the zillas run short and some say they dont, or should I just keep my 26's
The Zillas run small for sure. I ran a set of 26" on my can-am 400. You would have no problem clearing a 28". The Zillas will probably last longer. Interco makes the swamplite with a softer rubber that wears faster on rough surfaces.
Stock set up. No issues at all. Turns the 27"s over without a problem. I run a stock set of 25"s when I trail ride occasionally and I really can't tell that much of a difference except for getting sideways when cornering.
I am pretty certain you will be ok. ..I recently put 28x14 mega mayhems on my stock 13 500. Clutch kit is on the way. ...definate power loss with stock clutching.
