· Registered
Hello all, I own a 2021 Polaris sportsman 570 utility it is one that has a single tail light. I was wondering if anyone has done the sawp to the 2 tail lights version that are is higher up 570 trims?
if not is the wiring already pre existing to put in the 2 tail lights?
1st attachment with one tail light is what I currently have
2nd attachment what I want to change to
· Registered
I am gong to say yes its possible, the wiring harness on the single light does not have the connection for a second light but you should be able to splice a branch off the single to get the 2nd light. Lights are expensive, go to ebay. What I am seeing is the same part number for the light across many models so I am not 100 sure on this but they all look the same.
To do this it is about 200 bucks with used lights off ebay and using partshark for the rest. I am doing it on my wifes 2021 because I want it street legal and need two rear brake lights (stupid as motorcycles only need one)
· Registered
Oh and I ordered off the 450 EPS parts list
· Premium Member
Welcome to the forum
· Registered
Just a heads up- the onces on ebay for other models might needs some manipulating as they are 4 wires and the single light is a 3 wire. I am not sure how many wires or pins are on the stock 450 EPS with the dual LED lights but I am sure its is able to be done with a bit of splicing or soldering.
