I have a 95 magnum 425 2x4. I finally got it running thanks to tt425. Here is the wierd part. The battery will crank the quad all day but the only way it will fire and start is to have a battery charger on it for about a minute then remove the charger and she will fire right up. I have tried several different batteries all with the same result. My pull start is hashed so I cannot use it.. Any ideas??? Thanks, Dave
get a multi meter and test the battery, should read at least 12.2 volts , should read 13.5 or more when running and reved up a little
