I need to know what that switch inside the throttle housing is and how to adjust it and cable. I found the cable adjuster and the adjustable idle on carb. is there a adjustment on that switch and whats in side that box that on the carb. where the idle speed adjuster is. Thanks in advance for and help anyone can give.
O it might help if I said what it is. 1997 Polaris magnum 325
I need a manual looking on line NOW!
I had to take the cap off of mine and mess with that little tab that is supposed to push the button in. after I got it right I adjusted my throttle cable tight to have a good tension on it and it was good to go. now im just having issues with low idle and cant give it gas. think its a clogged jet. bout to tinker with it now. wish me luck. if you need any more info feel free to ask :) merry Christmas folks!
