1 - 10 of 10 Posts
The tie rod ends are the same part number for the 2004 and 2005 Sportsman. Does anyone know what the difference is with the tie rod itself? Is it longer/shorter? The 04 is p/n 5020926 and 05 is p/n 2134242.
If you're talking about the 500 Sportsman, the newer 2005 model tie rods are about 1/2"-3/4" longer because the newer Sportsman has different struts/springs and more front suspension travel among other changes.
The 2004 is 6.7"/170mm while the 2005 is 8.2"/208mm of front suspension travel.
I was talking about the one in my sig. 2004 600. Would that be the same?
Do you think the longer 05 tie rods would work ok on the 04 or would they be too long? The reason I ask is I got a deal on the All balls 52-1038 upgrade kit. $40. I wanted to install new ends and I figured I couldn't go wrong for $40. It should be at my house tomorrow.
Since you already have them coming I'd give them a try. Longer should be ok. Its when they're too short that you really have a problem since you can't adjust out far enough to get the tow out right without running out of threads.
Discussion Starter #8
That was my thoughts too. I guess I'll see this weekend. I guess worse case scenario, I could cut a few threads off... Hopefully it wouldn't come to that. Thanks.
So much for that idea. Amazon screwed me. Cancelled the order on the day I was expecting to receive it. No notice, just canx.
1 - 10 of 10 Posts
