1 - 1 of 1 Posts
Please help with a timing question. When I get every thing timed and reassembled, when i rotate from TDC around to TDC the cams are not timed. I was thinking if you are setting TDC and you make two complete rotate everything should be timed.
Is this a true statement?
Why wouldn’t it still be in timed?
Any help would appreciated
Thanks Tim
1 - 1 of 1 Posts
