Hi there, I just replaced my camshaft and am looking to get some tips on setting the timing on my 00' SP 500.
I have the flywheel bolt removed to view the timing mark on flywheel. I am a bit confused here. I see the straight line but i cannot see a mark to line it up with. I have the camshaft and valves all set at right location( i think) When i look in the flywheel hole, the line seems to be a bit forward. Does this mean i need to remove cam chain from the bottom gear and then put the top sprocket back on and reset? I have the service manual and have done everything but i cannot find a "v" looking through that hole to line up flywheel. Was just going by the straight line and how close to center of the hole it was....
any tips or advice is greatly appreciated..
