1 - 20 of 25 Posts
I am curious to find out if anyone has a tip on how to remove the cooked on dirt/mud off of the exhaust pipe? I cant seem to find anything that works, any tips much appreciated.
I like to wash my quad after getting it muddy of coarse letting it cool down 1st
Mean Green degreaser and a pressure washer if it is really caked on there. Where in Atlanta are you located? We ride all around the Jackson area all the time.
the exhaust itself? might be some rust to, got a picture?
I'm interested as well. I was gonna spray it down with wd-40 and go at it with a brass wire brush?...
I Don't use one( pressure washer). I wash after every ride. I think the OP and myself are talking about some really baked on stuff from muddy water hitting hot exhaust. Mainly on the headpipe area. I'll take a pic next time I'm out there.
Pressure washer works for me.
spray the pipes with hi heat ceramic paint...the good stuff...not rustoleum....do a few coats..should help with getting mud off....that paint you have to spray on..cook it on with exhaust heat an do again...works good
Discussion Starter · #12 ·
I am in Roswell, I have never riddin in Jackson, do you ride on private property or is there state parks I do not know about?
Discussion Starter · #13 ·
Here is a pict, a pressure washer doesn't seem to get it off for me... That being said I only use one when I am at a park using it at the washdown area. IMG_0925.jpg
Discussion Starter · #14 ·
Hmm, I just might of found a weekend project! Thanks for the advise.
Here is a pict, a pressure washer doesn't seem to get it off for me... That being said I only use one when I am at a park using it at the washdown area. View attachment 15945
Yea thats pretty much baked on. Looks like your engine and coolant/oil lines are discolored as well. Hand scrubbing with ajax might get u some where? Paint scrapper on the exhaust or wire brush.
this on an angle grinder will take it right off. Then repaint the whole exhaust with a high heat glossy finish ceramic paint. Wont stick/bake any more.
Discussion Starter · #17 ·
The only high temp ceramic paint I could find in glossy had a rating of 500 degrees. Will this work? All the higher temp paint was in flat colors.
Looks like mine.
What I wanna know is how is the rest of the underside of our ATV look so clean??:what:
Sent from my MB886 using Tapatalk
Discussion Starter · #19 ·
Lol. That's just after she got a bath using the motorcycle cleaner S100 I mentioned in another thread.
I'm trying that. I'm always skeptical of those type if things but that looks like it works!
1 - 20 of 25 Posts
