how big can you go with tires and wheels for an 850 with stock suspension
with out having any rub or problems?
Should I keep stock size or can I go a little bigger in front and back?
850 or 850 touring? the touring won't be able to fit as big of a tire as the regular 850.
sorry it's a touring
I put 27's on mine. They are radials. I had to trim the brace that supports the footwells and crank the springs up. Pretty happy with the outcome though. Bias ply tires are rounder than radials not sure if a 28 would work of not. I probably wouldn't chance it.
Thanks for all the info guys!!!
Have you noticed any additional wearing of the ball joints? Should I take that into consideration or is that not a problem?
