i have 02 scrambler freedom edition . it has 22x11x10 rear , 23x7x10 front . It needs tires but i have a set of 24x11.5x10 rear , 23x8x10 fronts . Would i cause any damage by running the taller on the rear than stock ? The fronts are the same height . thanks jeff
If it is a 4x4, you HAVE to stay with the same ratio difference between the two. The gearing is set up that way. If you change an inch in the rear, you have to change that same inch in the front.
2wd???? Knock yourself out!
That's interesting to know!
