$220 for the regulator and to be honest with you I don't think the larger tires would burn out the eps because it is actually easier to steer as there is not as much tire touching the ground because of the lugsso what's that going to cost you? could be worse. Could have been the larger mass of the tires and axles burning out the motor. not that that's not still a possibility later on down the road.
