have a 02 700 and found a nice set of mudlite xlt on ss 14 inch wheels tires are 27 x9 front & 27 x 12 rear any clearance problems and best way to resolve it thanks also will there be cluch or power issue useing 27" tires
If the wheels have the right offset,it "might" be ok without spacers.It wouldn't hurt to put a small lift on it for the 27's to clear good and a clutch kit will help with the little bit of power loss.
Discussion Starter #4 (Edited)
lift for 27 tires
been checking out the different types of lifts many to choose from wich one will work best with out to much modifications
The ones that have a bracket to raise the shocks are not too bad and pretty easy to install if you dont want to spend too much money,but highlifter,catvos and gorilla have good lifts but more expensive and more parts
