Hey guys just bought my first atv it is a 2007 Sportsman 800. The tires that are on there are 26x8x12 front and 26x11x12 Rear. It needs tires and I was thinking about getting the maxxis bighorn 2.0. will those tires fit in that size? It just seems like everyone says they run a little bit bigger. Also it looks like i can't get the fronts in 26x8 it is a 26x9? TIA
The 9" fronts may rub the tie-rod ends if ur running stock rims. I run 2.0's and they do run big. @ 5psi they measure 26.75".
Chances are your going to need a wider offset rim or wheel spacers to clear a 9" wide tire. Some tires run wider than others..
