I have a 400 trailblazer and i melted the piston last weekend. Took the top end off of the motor, need a new piston, rings and some machine work.
I bought the bike about 4 months ago, run it around the property and figured it was modded just by the way it ran. I didn't take it apart but it has a KTM exhaust pipe.
The main jet is a 240. As per the manual it is the stock jet. I run the bike at the beack on the sand dunes. What should i really have in it. Some one said i should put a bigger jet in it.
I was thinking of boring it 10 over, but not sure. Not trying to break the bank either.
Do the bore job, then go two steps larger on the main jet for starters. After that do a plug reading to see how it's running. Should be close. The jet is probably why it burned up, running way to lean.
A larger bore by .010", even up to .040" will not require a richer main jet. Been there many times. A lightweight wiseco piston, first size overbore with tolerances for the piston will make a nice difference in how it runs. Just be sure to let it warm up well before every ride. The forged piston expands faster than a cast piston, and many cold seize them because of that. The stock cyl ports are very rough, and a clean and match to the ports on that engine works well. I had porting done by hot seat, and they did a nice job. A friend of mine in Canada does nice port work as well, but any reputable shop could do a clean and match. The intakes should be bead blasted, the exh mirror polished. You need to keep a rough surface on the intakes to keep the fuel mixture atomized properly.
