1 - 2 of 2 Posts
Ok its a 2004 Trailblazer 250 2 stroke
I just put a top end kit in i did run it for like 5-10 without the exhaust pipe on to see if it fired i hope i did not harm anything... also i belive i bled the oil pump i pulled the lind off at the bottom of the cylinder oil was being feed through so i belive it is good.. the quad i thing is flooded i can get it to run with choke pulled out full way and drive it but it has no throttle response and then will bog out and die i nver let it warm up i just wnated to see if it ran before i broke it in .. the plug was covered in gas? so any ideas would hlep thanks guys
Z
1 - 2 of 2 Posts
