1 - 2 of 2 Posts
Anyone know what the required torque for the nut on front hubs for a 2002 sportsman 500 HO ?
if its the front spindle nut.....
it says to first torgue to 160-170 inch pounds while rotating hub....then back off nut 1/2 turn.....then rotate hub again..re torgue to 108-144 inch pounds..install cotter pin..if cotter pin does not line up tighten to align and install pin....do not exceed 144 inch pounds
1 - 2 of 2 Posts
