1 - 20 of 21 Posts
Decided to make a trailer for cutting wood and whatever else comes up, also good for kids to ride along in. Used a harbor frieght 40x48 trailer that I cut down to 25 wide and made adapters to bolt my factory rims to the axle .
Very nicely done. I will post pictures of mine in a minute. You gave me a goo idea though with making the mounting plate to mount up some bigger tires on mine.
heck of a nice build
Not quite as nice as yours but it works great for yard work and the side boards come off plus it tilts.
Nice builds. Personally I want a Walking beam trailer for mine. but thats a ways away.
Not sure about other state rules but here in MT atv's are street legal. So my question is has anyone hooked up brakelights and tail lights to their wheelers? If so was it easy to do? I have pulled mine around my town just because the cops say as long as they can see your brake lights on the atv while the trailer is behind you is ok. But I would like to have lights so I can just load my daughter's outlaw 90 on it with her on back of mine till we get to where we want to ride and unload hers and unhook the trailer and go (yes I live in a small town with tons of places to ride with in a mile of city limits)
You might be able to splice into your existing wires, and add a plug. Might want to use leds on the trailer so you dont blow a fuse.
Discussion Starter · #9 ·
I was going to put some tailights in mine eventually, that's all I was going to do was tap into the tail lights
deanler where did u get your hands on those wheel spacers to put atv hubs on trail bolt pattern? and I agree with thorshammer, walking beam would be the way to go, take some weight off the bike hitch and move easier on the rough stuff...
Discussion Starter · #11 · (Edited)
I had them water cut out at work then countersunk the screws, could make more if there's a need
Looked at doing a walking beam but everywhere I ride/cut wood is smooth trails. And I think they look rediculous Haha
Nice trailer..... I'm envious! Would like to build something like that myself for yard and woods work.
Not So my question is has anyone hooked up brakelights and tail lights to their wheelers? If so was it easy to do? I have pulled mine around my town just because the cops say as long as they can see your brake lights on the atv while the trailer is behind you is ok. But I would like to have lights so I can just load my daughter's outlaw 90 on it with her on back of mine till we get to where we want to ride and unload hers and unhook the trailer and go (yes I live in a small town with tons of places to ride with in a mile of city limits)
When I added my Wes seat/box, I tied into the rear tail/brake light wiring to operate the light on the seat. So it sould work just fine to run a small trailer light set. The idea of LED lights to reduce circut load is a good one too!
Mine started out as a harbor freight trailer also, and I spliced into quad wiring and have tail/brake lights, plus it's licensed. Also have a battery mounted on tongue with a solar maintainer for a couple lights inside and a 12 volt socket for plugging in phone charger, etc.
I had a similar adapter made, but run stock rims inside out due to clearance, just need to lay on ground to check tire pressure. Pulls easy and smooth with about 3 psi
I wired up the lights on my trailer. The 40x48 HF one and they have given me no problems
I would also like to know where those hubs came from. The little wheels out in the desert prospecting do some serious bouncing at times.
I had my adapters made at; Device Developement in Phoenix, if your down that way sometime, Matt or Jerry would probably remember making them.
Discussion Starter · #18 ·
what did he charge for them
__
I will be spending the Winter at Yarnell,AZ I may just look them up. Thanks The stock wheels I run almost flat in order to keep it from bouncing and add 2 five gal buckets of water for weight to hold it down. Dang I like your trailer !! and my quad is black and silver that trailer would look so nice behind it :)
1 - 20 of 21 Posts
