A friend wants me to pull his pop-up camp out of his back yard, I wanted to ask anyone
if I would hurt my 4 wheeler if I did this. I just don't want to damage the rear-end or anything
else. Thanks to all
I guess it depends on how big of a camper it is, I pull my pop-up with my 570 no problem. Make sure you use low gear & go slow.
If the weight is low so you can tow with that, i also do sometimes I have Ram 1500 diesel engine truck which i use for Rite way towing service, but when weight is less so use my Polaris..
You might be over thinking this. If you're not doing hills, or need to stop it while at higher speeds, you can nearly tow anything. Here is a Rhino towing a trailer with atv and a sled on it. No hills or speed was done.
