I've got a Trail Boss 250 and I'm unsure of the year. Any info would be appreciated:
Lower left A-arm is number 4XAAA25C6W2107865. I'm pretty sure the numbers are correct. It's a little hard to read as the numbers are electro-pencil stenciled on the frame.
On the right side pull starter is a white tag with the following: Ser No 9852442
Prod No EC250PFE100 4017
I also need a manual for it if you know someone with one laying around.
Thanks, Matt.
Great!! I was told it was a '96ish model. As far as the engine is concerned are the parts the same? I ordered a top end rebuild kit for a 96 model based on what I was told. Thanks, Matt.
your welcome.Does the kit have a wiseco piston?
