I am trying to put together a minimal socket set to go in the toolbag I keep in the rear box of my 550 XP. I was going to go with a 3/8 drive handle, a 3" extension and want to know what specific size sockets (SAE and metric) should I plan to include.:hmmm:
Thanks for your help!
I don't know about the very new machines but you shouldn't need any metric. I carry 3/8 thru 5/8 sockets and wrenches and a 6" extension and plug socket. Two torx bits. One is a T25 and I can't remember the other size but they fit both size torx screws on the machine. A changeable bit screwdriver with various size and types of bits. A small adjustable wrench and a set of vicegrips. That selection will fix just about anything on my 800.
I also carry a small length of mechanic wire rolled up, some zip ties, electrical tape and a spare plug. All this goes in a one gallon ziplock freezer bag in the rear box along with a small Slime air compressor kit with a small bottle of Slime, tire plugs and plug tool and a valve stem tool. I also can stuff a set of yuasa atv booster cables and a 15' tow strap in there. Oh yeah, I carry a spare belt too on really long trips. If you blow a belt in the boonies your machine is dead unless you can change it!
I haven't needed pulled out of the woods yet but may be jinxing myself by saying so.
Thanks. I don't keep the tape in the rear box as it gets warm in there. No metric eh?
Thanks again.
You might want to check your particular machine but no metric on mine. One other thing I forgot to mention was a couple of allen sockets to fit the brake calipers.
