41 - 59 of 59 Posts
That axle would be an easy repair, but a machine shop would charge at least $95 to fix it - PSN guarantees their parts, so I would consider getting the used one and a sprocket hub if they have one.
Discussion Starter #46
I found a guy selling a 2001 trailblazer. I haven’t looked at it yet. But do you think the rear would match mine?
Discussion Starter #48
So....I’ve been finding a ton of axels that are suppose to fit my bike but they all have splines and threads. Mine has splines only. Why??? I’d like to have more options than the one shown from psn. Even the schematic shows threads. Should I swap axels??
No, the change was in 05 - the 04 and earlier axle has threads - the 05 and later has no threads - the 05 used snap rings and the threads are on the sprocket hub. The earlier axle used nuts to pull the axle up against the bearings. The later design used a nut that pushed against a ring to tighten the axle into the bearings. Same principle, but opposite forces.
You can swap and entire 04 and earlier axle, housing, hubs and all into an 05, but there is no guarantee the sprockets will align properly.
98 to 04 swing arms , axles and bearing housings are mostly the same for the following models:
1998 SCRAMBER 500 (W98BC50A)
1998 SCRAMBLER 400 (W98BC38C)
1999 SCRAMBLER 400 (A99BG38CA)
1999 SCRAMBLER 400 (A99BG38CB)
1999 SCRAMBLER 500 (A99BG50AA)
2001 TRAIL BLAZER (A01BA25CA)
2001 TRAIL BLAZER (A01BA25CB)
2001 TRAIL BOSS (A01AA32AA)
2001 TRAIL BOSS (A01AA32AB)
2001 TRAIL BOSS 325 SE (A01AA32AC)
2001 XPLORER (A01AG25CA)
2001 XPLORER 400 (A01CG38CA)
2002 TRAIL BLAZER (A02BA25CA/CD)
2002 TRAIL BLAZER FREEDOM (A02BA25CB)
2002 TRAIL BOSS (A02CA32AA/AB)
2002 XPLORER 400 (A02CG38CA)
2002 XPLORER 4X4 (A02CG25CA)
2003 TRAIL BOSS 330 (A03CA32AA)
2004 TRAIL BOSS 330 (A04CA32AA/AB/FA)
The swing arm in the 05 Trailblazer was the same for these models:
2005 SCRAMBLER 500 4X4 (A05BG50AA)
2009 SCRAMBLER 500 4X4 INTL (A09BG50FA)
2005 TRAIL BLAZER (A05BA25CA)
2006 TRAIL BLAZER (A06BA25CA)
2007 SCRAMBLER 500 2X4 INTL (A07BA50FA)
2009 SCRAMBLER 2X4 INTL (A09BA50FA)
So without some deep research, you need an axle and associated parts for the 05 and up only
The axle polman gave you a link to CLICK HERE will fit your machine - the axle (part number 5133967) fit these models:
2005 SCRAMBLER 500 4X4 (A05BG50AA) - Rear Housing /Fa
2005 TRAIL BLAZER (A05BA25CA) - Housing, Rear /Cb
2005 TRAIL BOSS 330 (A05CA32AA) - Rear Housing /Ab/Ac/Fa
2005 TRAIL BOSS 330 QUADRICYCLE (A05CA32EA) - Housing, Rear
2006 SCRAMBLER 500 4X4 (A06BG50AA) - Housing, Rear /Fa
2006 TRAIL BLAZER (A06BA25CA) - Housing, Rear
2006 TRAIL BOSS 330 (A06CA32AA) - Housing, Rear /Ab
2007 SCRAMBLER 500 2X4 INTL (A07BA50FA) - Suspension, Axle, Rear
2007 SCRAMBLER 500 4X4 (A07BG50AA/FA) - Transmission, Rear
2007 TRAIL BOSS 330 (A07CA32AA) - Transmission, Rear
2008 SCRAMBLER 2X4 INTL (A08BA50FA) - Drive Train, Rear Axle & Housing
2008 SCRAMBLER 500 4X4 (A08BG50AA) - Drive Train, Rear Axle & Housing
2008 SCRAMBLER 500 4X4 INTL (A08BG50FA) - Drive Train, Rear Axle & Housing
2008 TRAIL BLAZER 330 (A08BA32AA) - Drive Train, Rear Axle & Housing
2008 TRAIL BOSS 330 (A08CA32AA) - Drive Train, Rear Axle & Housing
2009 SCRAMBLER 2X4 INTL (A09BA50FA) - Drive Train, Rear Axle & Housing
2009 SCRAMBLER 500 4X4 (A09BG50AA) - Drive Train, Rear Axle & Housing
2009 SCRAMBLER 500 4X4 INTL (A09BG50FA) - Drive Train, Rear Axle & Housing
2009 TRAIL BLAZER 330 (A09BA32AA) - Drive Train, Rear Axle & Housing
2009 TRAIL BOSS 330 (A09CA32AA) - Drive Train, Rear Axle & Housing
2010 SCRAMBLER 500 4X4 (A10NG50AA) - Drive Train, Rear Axle & Housing
2010 SCRAMBLER 500 4X4 INTL (A10NG50FA) - Drive Train, Rear Axle & Housing
2010 TRAIL BLAZER 330 (A10NA32AA) - Drive Train, Rear Axle & Housing
2010 TRAIL BLAZER 330 INTL (A10NA32FA) - Drive Train, Rear Axle & Housing
2010 TRAIL BOSS 330 (A10EA32AA) - Drive Train, Rear Axle & Housing
2010 TRAIL BOSS 330 INTL (A10EA32FA) - Drive Train, Rear Axle & Housing
2011 SCRAMBLER 500 4X4 (A11NG50AA) - Drive Train, Rear Axle & Housing
2011 SCRAMBLER 500 4X4 INTL (A11NG50FA) - Drive Train, Rear Axle & Housing
2011 TRAIL BLAZER 330 (A11NA32AA) - Drive Train, Rear Axle & Housing
2011 TRAIL BLAZER 330 INTL (A11NA32FA) - Drive Train, Rear Axle & Housing
2011 TRAIL BOSS 330 (A11EA32AA) - Drive Train, Rear Axle & Housing
2011 TRAIL BOSS 330 INTL (A11EA32FA) - Drive Train, Rear Axle & Housing
2012 SCRAMBLER 500 4X4 (A12NG50AA) - Drive Train, Rear Axle & Housing
2012 SCRAMBLER 500 4X4 INTL (A12NG50FA) - Drive Train, Rear Axle & Housing
2012 TRAIL BLAZER 330 (A12NA32AA) - Drive Train, Rear Axle & Housing
2012 TRAIL BLAZER 330 INTL (A12NA32FA) - Drive Train, Rear Axle & Housing
2012 TRAIL BOSS 330 (A12EA32AA) - Drive Train, Rear Axle & Housing
2012 TRAIL BOSS 330 INTL (A12EA32FA) - Drive Train, Rear Axle & Housing
2013 TRAIL BLAZER 330 (A13NA32AA) - Drive Train, Rear Axle & Housing
2013 TRAIL BLAZER 330 INTL (A13NA32FA) - Drive Train, Rear Axle & Housing
2013 TRAIL BOSS 330 (A13EA32AA) - Drive Train, Rear Axle & Housing
2013 TRAIL BOSS 330 INTL (A13EA32FA) - Drive Train, Rear Axle & Housing
Hey. New is too much for me. Here are pics.
That machine has been run a long time with the bearings out to wear it down that much. And that answers the question I asked earlier about why you wanted to replace the housing... it'd be torn up beyond repair too.
You may as well bite the bullet and get the axle I showed you before it gets away.
What you need is a MAGIC WAND!
Discussion Starter #54
I sure do! Lol. So I bit the bullet and ordered the axle. Now I need the housing 5134460. Preferably used. And the hub sprocket. I’ve been looking but I want good parts and good prices!
Discussion Starter #56
Awesome! Thank you so much. I should get the hub sprocket off the other stuff first to see if I need other parts. As far as o rings and spacers and little parts that I never had I’m kinda stuck. Where do I find them and then where do I install them? I need a manual!
Send me your email address in a PM - include which model you need the manual for - I might remember, but it's easier if you remind me.
Vehicle Information
Model Name
TRAIL BLAZER 250
Model Year
2005
Model Number
A05BA25CA
Purchase Date
2/3/2006
VIN
4XABA25C752751054
Engine Serial Number
000000554846
Warranty
Factory Warranty
Start Date
2/3/2006
Expiration Date
8/3/2006
Here ya go latebird
41 - 59 of 59 Posts
