Howdy everyone. I just picked up a '98 Trailblazer and I'm trying to find out where all the plugs and wires go on the circuit board on the front below the steering stem. Any ideas where I could get a diagram for it? Or should I just get a Chiltons manual for it? Does Haynes make one? Thanks guys.
The board should have all the wire codes on it in white letters telling you which color wires plug in to which spot. if not i could probably take a picture of mine for you.
I can make out some of them. Most are worn away. If you could get a picture I would really appreciate it man! Thanks! :D
@Bait, thank you for the circuit diagram that you uploaded. I was having the same issue which then turned out to be just a wiring mistake from the repair guy that I typically use. He had used wrong color codes for positive and ground wires. Anyways, I hope @wertzy’s trailblazer is now running completely fine. Thank you for sharing these images they are a big help. I was actually in the garage trying to finish the wiring for the last three hours and got tired. Came back and found this amazing forum. Thanks again.
printed circuit board
Discussion Starter · #7 ·
Yeah I got mine all wired up right. Now I'm just waiting for my cylinder to get back from Passion Racing Engines for a bore and hone job. :D
