I got a trailboos 250, the motormounts all broke, so i replaced all of them, put it all back together, got it running good but now when I move the shifter to high, low, or reverse it won't move, it all worked before I replaced the motor mounts, so any help would be appreciated. ...
Sent from my SGH-T999 using Tapatalk
You may not have put the motor back in the correct position for the length of the belt,otherwise front clutch may just need cleaning.
Remove clutch cover and see what's wrong.
Thanks I'll try that, the knob on the rear brakes how do youadjust that
Welcome to the board!:med:
