Trailboss 350L running poorly.....found problem....not the carb!
2.6K views 7 replies 3 participants last post by  n4cer26
149236
149237
So, my newly purchased 91 Trail boss 350L was barely running. I rebuilt the carb and there was no improvement. Engine would run only on choke while feathering the throttle.
I decided to take off the rubber manifold to check for cracks. When I did I also inspected the reed cage and found a large piece of flexible material stuck in one of the reed petals. The petal was permanently being held open approx 1/4 inch. I have flipped the reed petals over and will be reinstalling. My question is....where the hell did this piece come from? Pics posted below.
#4 ·
The reeds appear to be Boyensen fiber reeds and if not broken are fine - yeah, what is material and where did it come from?
Part of the air filter? Something that got or was put inside the air filter during a moment when the air filter was off?
Let us know if you determine what it is and where it came from.
#6 ·
I agree - it kinda looks like RTV or another silicone adhesive product - silicone is not gas or oil resistant and should not be used where exposed to certain chemicals - look to see if someone tried to repair a tear or split in the intake with the chit - even using it as a sealant between the read cage and carb holder can result in your experience.
