I've got 8' ramps for my tandem axle flat bed trailer. They are a bow string design (picture below) and are conservatively rated to hold 3200 lbs each. they weigh about 40 lbs and are made of 1"x2"x1/8" rectangular tubing, 1"x3/16" flat strap, and 2"x2"x1/8" angle iron. The load rating was given with the main rails straight and the "bow string" arched, but when I built them I arched the main rail and kept the bow string straight. which increased the load rating. I can load a Case Skid steer with my 8' ramps and they cost me less to build than any commercially available ramp I've found on the market, and a fraction of the cost of ramps that would support the same load. they slide under the deck of the trailer out of the way and can be used for rear loading and side loading.
The biggest draw back for the tail gate ramps for me is the lack of versatility. You've got one ramp, in one spot, and that's it. Now, depending on the design of the trailer, that might be just fine, but just not for me.
